Eclipse watching
studmuffin
Cannot advise about welding helmets, but i can offer a simple and free solution.... Assuming you have access to a bucket or a bowl and some water.
Fill the vessel of your choice and stand on a stable surface outside... Watch the eclipse in the reflection.
(This method does not guarantee that the sky will be clear of clouds though....)
Neil
...I used welding glass - 13 grade - for the full eclipse in '99 in Cornwall . It was a bit cloudy but the sun was visible and
a most spectacular experience . We were on the Cheese Wring stones along with about 10,000 people up on the moor . If I won the lottery
eclipse chasing would be high on the list of things to do .
Got everything crossed that the cloud will stay away for this partial one
cheers
Steveb
When I was a kid I used my dads welding helmet to watch an eclipse and again in '99 used a lens from a welding helmet to view an eclipse (during a work meeting IIRC) anyhow I'm still able to see, make of that what you will.
Yep, same here. Back in '99 I used a Speedglass helmet we had at work. My eyes still seem ok.
Back in '99, I used a disc out of a 3.5 floppy disc folded over into a semi circle. My eyes seem ok, and my guide dog agrees. :stirthepot: Seriously, I don't recommend this method, but a no 14 welding glass has to be better than projection viewing. The temptation to peek with the projection method must be hard to resist.
I've booked a left hand seat in the plane on my way home on friday, if the flight is delayed by just a few minutes I will see it from above the clouds.. it will be my luck to drop through the clouds into the Manchester rain ten minutes before it happens :-(
