Anderzander Posted March 17, 2015 Share Posted March 17, 2015 Excuse my ignorance ..... I have a replacement bell housing cross-member to replace the rotten one ok my series. Do I ensure it goes back in the right place just by scribing lines to locate it ? ... When I cut the old one out and grind it back flush I presume some lines across the top of the chassis rails will adequately locate it front to rear ? And lines scribed on the inside of the chassis will locate it's height ok ? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 17, 2015 Share Posted March 17, 2015 Lines are good, but better still follow up the lines with some centre pops. Lines can get lost with the grinding and cleaning up, pops re much harder to loose Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 18, 2015 Author Share Posted March 18, 2015 Great - thank you. Obvious now you've said it - but losing the scribes was exactly my concern. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted March 18, 2015 Share Posted March 18, 2015 Be careful the thing doesn't creep upwards. I was under a S2a with a chassis that has been entusiastically welded (superficially looks wonderful) and I can just about get a piece of paper between the clutch housing and the crossmember. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 18, 2015 Author Share Posted March 18, 2015 Thanks - good tip. Perhaps I can tack it into position with the bellhousing in situ, so it acts as another datum. Quote Link to comment Share on other sites More sharing options...
