manxrover Posted March 21, 2015 Share Posted March 21, 2015 Hi Just a follow up on the problem I had with the TD5 seems to run out of fuel, diffcult to restart, lots of smoke on restart, and then cuts out again. New injector loom fitted cleaned red plug no change New fuel pump fitted no change New fuel filter and housing with new air bleed valve. no change New crank sensor fitted no change New injector washers and seals fitted no change. The problem turned out to be the fuel regulator I did not change this as some guys on the forum said " there is no need to change the reulator unless it's leaking" so i asumed mine was ok as no leaks where visible. The guys at my local Land Garage say the the regulator sticks and looses fuel pressure. So if any one has this problem and looking at the forum there seems to be a few. Check the regulator first, before spending loads of money on spares that's are not need. Can I suggest that anyone who has resolved any problems, post the reslts of the fix on the forum, so we can all see what the problem was and how to fix it. Brian 1 Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 21, 2015 Share Posted March 21, 2015 Thanx for this, it is all too often the one post wonders come looking for help but never let us know whether we did or not, good info of problem, symptoms and final resolution. Quote Link to comment Share on other sites More sharing options...
