RustyNissanPrairie Posted March 21, 2015 Share Posted March 21, 2015 Looking to order a replacement galv Marsland chassis soon for my 110 with mounts to suit my 200TDI, but also thinking about future proofing it and having 300tdi mounts also fitted seeing as there are loads more 300 engines knocking around than Defender 200's. I emailed Marsland but without reply. Is it possible and has anyone done this previously on their chassis? TIA Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 21, 2015 Share Posted March 21, 2015 IIRC - when I ask Richards they said not as they interfeared with each other ! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 21, 2015 Share Posted March 21, 2015 Just choose one, and then when you change engine in the future, build engine mounts to match up with the chassis side of the mounts. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 22, 2015 Share Posted March 22, 2015 My replacement chassis came with no engine mounts but with lots of different inserts to bolt on mounts. I bought L&Rh 2.5 petrol mounts to mount my 200 on. They bolted straight into place on the chassis. Mo Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 22, 2015 Share Posted March 22, 2015 The 300 exhaust runs through the 200 mount position, so no, it's not possible. The Defender version of the 200 may have clearance issues between the injection pump and the 300 mount, while the oil filter is almost certainly an issue. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted March 22, 2015 Author Share Posted March 22, 2015 My replacement chassis came with no engine mounts but with lots of different inserts to bolt on mounts. I bought L&Rh 2.5 petrol mounts to mount my 200 on. They bolted straight into place on the chassis. Mo That sounds interesting ! Who's chassis was that? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 22, 2015 Share Posted March 22, 2015 Genuine. Made by Marsland I believe. HTH Mo Quote Link to comment Share on other sites More sharing options...
