baughany Posted March 23, 2015 Share Posted March 23, 2015 Hi I ve recently bought an 03 l322 td6. It seems to be leaking diesel into the engine oil. Please help? Regards Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 25, 2015 Share Posted March 25, 2015 If diesel is leaking into the engine oil it can (in my experience) only be a dodgy injector not sealing off. If this is the case it drains the system pressure into the cylinder, it then overnight leaks past the piston and into the sump, there is also the horrible possibility of hydraulic damage to the piston. Remove all the injectors and have them tested and replace the leaking one. Quote Link to comment Share on other sites More sharing options...
