Leaf springs
Anderzander
The recent topics around series ride quality and available springs, has brought to mind the narrow springs on my 80"
I don't want to lose originality and change them for wide ones - so my options are pretty much just having some made or having these re-set.
Can anyone recommend either route ? and / or a company to do it ?
I bought a pair from Craddocks to fit my 80" last year. And so far I'm very pleased, no sagging or warping. My original ones are actually in an okay condition though they have gotten a little flat over time, but not much. But i figured I might as well change them while new ones are still available so the genuine ones now reside happily in the garage :)
I had good results from getting leaf springs reset, but from what the guys at the shop told me, its really only classed as a temporary fix as they can sag back again. How long that takes, is down to how much weight you carry, how rough the terrain it gets driven on is etc.
I got my leaf springs reset (albeit in a 70 series cruiser) and I asked for a small amount of extra arch to counteract the re-sag if it ever occurred. I was blown away by how much better the ride was!
All 4 cost me around $600 NZD and that included them removing, refitting and re-bushing the componentry. A worthwhile option if you can't get decent new ones in my eyes.
Josh
Hey that's helpful guys - thank you !
I wasn't sure about the quality of new springs - so encouraging to hear yours are ok Soren.
Good feedback on the resetting too - how is that specified I wonder. Would I provide a distance between the eyes and they set it to that I wonder ?
Thank you Mr Stuck - I'll have a look at them :)
Specifying the distance between spring eyes would be the most logical way, I don't know if that's what they actually do. I guess the shop would be able to find a specs list (worrying with LRs tolerances!) and set them to that.
I wouldn't recomend resetting springs when I was running my custom shop I had a client push for a custom pack and get them re-arched... I went with a local outfit I'd heard good comments about, 4 yrs later they are lower than where we started.... he hasn't used it to carry loads infact it probably spend 2 of those yrs sitting parked up
Based on this I did a fair bit of research.... first not all spring steel is equal, and you can't apply the same treatment to different steels and expect the same results.... next there are alot of variables in the process first they have to normalise, some steels might require multiple normilsing treatments, then bend, then heat treat to harden and then heat again to temper so they will bend without braking now each one of these needs a different heat, time to soak in this heat and a technique to cool.... get any of this wrong and it won't be hard enough or too hard, then the temper phase same deal but with the added fun some steels like multiple temper treatments
New steel comes with spec sheets detailing all this and the ranges, easy to get a good result for a specialist... now when its old springs its best guess as to what to do
Add to this there are alot of guys that work off a colour chart as to the heat (the colour of the glow when hot) this gets vague as things as simple as cloud cover can change the tone of a colour making it possible to miss read the colour and change things alot
this is incidentally the tech the local guys work with and kind of explains why I got a waist of money job
Unless you can find a specialist who has done lots of landrover springs I recomend not risking your current springs or your money.... new springs might seem like a lot of money but in the long term they are a better investment
Just a side note if you do decide to do this when I've done this I spec'd the height taken from a line across the top of the spring eyes to the spring seat.... this gave them the arch
No Need to heat to re arch, we used to do them cold here, the primitive way with a big ass sledge hammer and piece H beam. We were young and foolish as it was dangerous, and used to spend a day with ears ringing.......................
I always did mine at home in a simple jig with a bottle jack. If you have press its even better.
G
I've only tried resetting springs once, but have helped on another occasion. In both cases we used a big old Roller for the job and slowly re-arched them cold. However I can echo DeRanged's experiences, within a year and a half both sets was flatter than when we started! And with all the work that went into it I doubt I'll ever do it again. Only reason back then was lack of money.
G
I well remember helping some friends use the sledgehammer technique with a MkII Cortina's springs when I was a teenager. One leaf broke and exploded upwards, knocking my mate out cold with blood streaming out of his head. A quick trip to hospital and he survived but I would NEVER do this again!
