need4speed Posted March 25, 2015 Share Posted March 25, 2015 I noticed when going to fit dash trim..Part 14 in diagram.That there are no holes in my bulkhead to accept the little plastic clips to hold it in place. I presume my bulkhead must be late td5 as i dont think they had this dash part.Anyway im going to have to drill some holes in bulkhead and use self tappers. Ive been using stainless fixings where i have been able to wrap with ptfe tape (to avoid galvanic corrosion) but obviously i cant use this on self tappers. So to try and avoid the self tappers corroding in place will i be better to just use normal mild steel screws? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 25, 2015 Share Posted March 25, 2015 Can you not use the plastic clips ? Or alternatively - on my last 90 I pulled mine out to fix a dodgy header and put it back, but left the clips out in case I hadn't fixed the problem - and I ended up leaving it like that for a couple of years. It never moved or creaked or rattled ... With the other trim pieces holding it in place. Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2015 Share Posted March 25, 2015 just get a bag of the plastic pins item 15 in http://lrcat.com/#31/4/53604 note there are 3 colours so if you go for these make sure you order to match your tray colour or use stainless self tapping screws, Quote Link to comment Share on other sites More sharing options...
