Stumpybike Posted March 28, 2015 Share Posted March 28, 2015 Hi I've just changed my A frame fulcrum and ball joint, no problem. On replacing I've tightened up the castle nut and it's way past the split pin holes. Is this normal or is something missing, I have put the new washer on. Or is it a case of using more washers Cheers Quote Link to comment Share on other sites More sharing options...
Team Idris Posted March 28, 2015 Share Posted March 28, 2015 It could be the taper hole is worn? Mine certainly is mine wasn't so worn I was off the hole, but it was worn enough to put an R clip through it so I can make sure it is tight on a regular basis. I can't see a washer being an issue as long as the housing isn't so close to the mount that you cannot get full flex? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 28, 2015 Share Posted March 28, 2015 I believe the wsm says tighten torque and then line the holes up for the split pin. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 28, 2015 Share Posted March 28, 2015 That's the way I was taught to do on both a slotted and a Castlated nut. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 28, 2015 Share Posted March 28, 2015 I believe the wsm says tighten torque and then line the holes up for the split pin. I think he means the pin hole is a long way down from the bottom of the nut. Quote Link to comment Share on other sites More sharing options...
