88 rear axle on a 109
neonovice
I ire the springs sit out wider on a 109 in comparison to an 88, also the rear of a 109 is Salisbury, most likely because a rover axle is much weaker, what kinds of work does your truck do?
Not only would you have to move the spring saddles, you'd need to weld on damper brackets, get a custom longer prop shaft and swap the brakes over too. That would leave you with with a very weak vehicle at more expense and difficulty.
  • Like 1
