Mghay Posted April 3, 2015 Share Posted April 3, 2015 Any suggestions to solve intermittent power supply to rear windows? I thought it was a poor connection somewhere, perhaps bad earth? Usually OK, sometimes needed quite a few presses to work but now unable to open either window (fuse checked OK) from any switch. I have removed/refitted front switch connectors. Quote Link to comment Share on other sites More sharing options...
teabag Posted April 3, 2015 Share Posted April 3, 2015 Iffy PCB solder joints in the window ECU maybe, it's a common issue according to the Forums. There are a few threads with pictures somewhere on the www. Quote Link to comment Share on other sites More sharing options...
Mghay Posted April 4, 2015 Author Share Posted April 4, 2015 Thanks. Found this: http://www.discoweb.org/window/index.htm Took rather more than the 15 mins quoted but it works! Problem fixed. Quote Link to comment Share on other sites More sharing options...
