Raggylad Posted April 29, 2015 Share Posted April 29, 2015 I am experiencing a small persistent oil leak from the Fairey overdrive on my LT95 box. Symptoms: - When the box is cold, there is no leak - Once up to driving temperature (therefore possibly connected to viscosity ?), there is a slight leak which appears to be coming from where the actuating rod enters the O/D casing - Every time I change the O/D in or out, a spray of droplets is emitted (covers the handbrake drum, the back of the 110, any trailer and presumably the windscreens of following vehicles) - Rate of loss isn't massive - less than a pint from the T Box (from which the O/D is splash lubed) every 3,000 miles There doesn't seem to be any obvious way of effectively fitting any sort of seal to prevent this. Has anybody experienced this ? Is there a solution that works ? More widely, any ideas for a cure ? Thanks (Also posted on the Defender forum, but 110 V8s with LT95 boxes are pretty rare nowadays so posted here in the hope of catching early RR Classic expertise) Quote Link to comment Share on other sites More sharing options...
