heath robinson Posted May 15, 2015 Share Posted May 15, 2015 I've used the yellow job, and as said above, was thoroughly unimpressed - spend the extra £20 if you really want a hydraulic one. Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 20, 2015 Share Posted May 20, 2015 Well, I've bought the same crimper as Mutley. I've tried it on a 35mm cable and a 50mm cable. Quite disappointed really. The 35mm didn't look a great crimp, and indeed I pulled it apart without too much effort. The 50mm was a joke, the crimper hardly marked the terminal at all - it's totally the wrong size. I need to do some 70mm cable next, I think that might be more successful given that when I compared the 50mm die to the 70mm die there was virtually no difference in size. To get a good crimp I've had to use the next size down very carefully, rotating round the crimp. However, after doing this it does actually produce a good crimp - I've cut one of them open to check and there was no air gaps etc. Not bad enough to send back as I can make it work, but I hoped for better. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 21, 2015 Share Posted May 21, 2015 As a budget alternative - I bought one of the manual ones, like this : https://www.amazon.co.uk/dp/B00O9XNKE2/ref=cm_sw_r_awd_Ooyxvb1KPH907 I paid less than the linked one though it's the same type - and it's been very good. Quote Link to comment Share on other sites More sharing options...
zardos Posted May 21, 2015 Share Posted May 21, 2015 I don't think you can beat http://www.thetoolboxshop.com/0-703-80-heavy-duty-crimp-tool-for-cable-terminals-10mm2-to-120mm2-1015.html for quality of crimps, but not cheap. Quote Link to comment Share on other sites More sharing options...
