Fitting a new tank
Chaps,
My 110 tank has split and I have a new one arriving today along with all the seals, screws, senders, and returns.
My question is I am able to build the tank up with the senders and return section before fitting......obviously the return pipe as that is at the top of the tank but can I pre-fit the sender unit into the tank and then raise the tank into position?
I will also be sanding, priming and coating the tank and cradle to ward off the rust for as long as possible. I have a few tins of black Hammerite at home will this do the job??
Many thanks for all your help.
Bish
