Anderzander Posted May 10, 2015 Share Posted May 10, 2015 I have a Td90 with the electric headlight adjusters and could do with replacing some of the adjuster screws - which seem to come with a spacer and locking washer ...... Could anyone point me to the part number(s) please ? Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2015 Share Posted May 10, 2015 See item 9 in http://lrcat.com/#31/4/52870 --- BHM7058L only for manually adjusted headlights, shouldn't need these with electric adjusters, none listed in the parts page for electrically adjusted headlights http://lrcat.com/#31/4/52868 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 10, 2015 Author Share Posted May 10, 2015 Thanks Ralph It's not electric adjustment - just the level switch for towing What I was looking for is in the box labeled 9 - as part of STC1614. Except a search for that doesn't reveal the same as is fitted to mine.... I'll have a think. Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2015 Share Posted May 10, 2015 No to STC1614, item 9 in the first link BHM7058L for manual adjusters, will be the same on load levelling fitted lights, 2 per headlight, one at top & other on one side. they usually come pre-fitted to new headlight bowls, not normally a item that gets replaced until the metal bowl rusts away. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 10, 2015 Author Share Posted May 10, 2015 They are a bit different - plastic bowls and three mounts - two either side (at 3 and 9 o'clock) and the electric one at the bottom (6 o'clock). I'll see if I can get a picture, but a bit like the longer ones here: Except it's a countersunk machine screw, with a washer, some sort of nylon/rubber spacer, and then a locking washer to hold the bezel at the front of the screw. Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2015 Share Posted May 10, 2015 those are the same as mine Wipac plastic bowls. can't see any spare ones on Wipac website but a email might reveal a result http://www.wipac-aftermarket.com/uk/acatalog/Contact_Us.html http://www.wipac-aftermarket.com/uk/acatalog/Components.html Quote Link to comment Share on other sites More sharing options...
