Hybrid_From_Hell Posted May 10, 2015 Share Posted May 10, 2015 Hi all, In the bigerewire-a-thon I have found that I have a humungous Indicator relay as in pics ?? I seem to recall that this type maybe for the LR having towing electrics (which mine does not ) and that for just ordinary indicators I can / could fit a "Nonmal" sized induicator relay ??Anyone help / part number etc ?? Just that its so Ferkin big lid won't fit over new fuse / relay box lol !! Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 10, 2015 Share Posted May 10, 2015 Its a towing relay yes. Just get another with the same number of pins. Try VWP. But they are all usually quite tall. Only exception is if you have LED lamps, then you will need an electronic one. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 10, 2015 Author Share Posted May 10, 2015 can I use a later std LR say defender one ? and if so whats the part number / is it more a normal size relay ?No, don't have LEDs lol! Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 10, 2015 Share Posted May 10, 2015 The flasher in my 110 was a big yellow one about the same size as that. Thats all i can add. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 10, 2015 Author Share Posted May 10, 2015 OK ....see what others might be able to help with Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted May 10, 2015 Share Posted May 10, 2015 http://new.lrcat.com/#!/1228/10541/12364/969/12376 number 2 with out socket. YWT10003 Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2015 Share Posted May 10, 2015 (edited) same as mine it's meant to live on bulkhead side of fuesbox metal panel mounted sideways. it'll still operate with no towing electrics fitted. it also supersedes previous units, see the s/s numbers under description. http://www.lrseries.com/shop/product/listing/10027/PRC8876-RELAY-FLASHER-UNIT.html non towing electrics version is a 2 pin round thing http://www.brit-car.co.uk/product.php/93242/0/flasher_unit_2_pin_s111_def Edited May 10, 2015 by western Quote Link to comment Share on other sites More sharing options...
tacr2man Posted May 10, 2015 Share Posted May 10, 2015 LAND ROVER DEFENDER 90 110 130 INDICATOR FLASHER RELAY 4-PIN - PRC8876 or this http://www.ebay.co.uk/itm/NEW-UNIVERSAL-FLASHER-UNIT-RELAY-INDICATORS-12V-LIGHT-TURN-SIGNAL-3-PIN-160116-/181582442159?pt=LH_DefaultDomain_3&hash=item2a47282eaf htsh Quote Link to comment Share on other sites More sharing options...
