reb78 Posted May 12, 2015 Share Posted May 12, 2015 As above, will they fit? Has anyone done it? I currently have a series seat box to fit, upon which I plan to fit my old front seats, but I have seen a set of d2 seats fairly cheap and wondered if they would be an easier option? Any thoughts? Edit: title shoud read 'in the back' (blasted ipad!) could a mod correct please? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 12, 2015 Share Posted May 12, 2015 I know D1 second row seats can be fitted into the back of a 109 with a little bit of modification of the tub, so I imagine fitting D2 seats in a 110 would be pretty much the same. I'm not sure where to look for the pictures now, but IIRC it involved cutting a portion out of the sloping front of the tub's wheel boxes, then just putting in a flat bottom and a vertical wall. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 12, 2015 Share Posted May 12, 2015 If you have a seat box fitted in the back 5 door freelander rear seat will fit quite well. I am fitting some in the my ibex see here http://forums.lr4x4.com/index.php?showtopic=82834&page=3 will give you an idea about half way down the page. Mike Quote Link to comment Share on other sites More sharing options...
