brokenthings Posted May 12, 2015 Share Posted May 12, 2015 Here's the short of it. My winch stopped working. I disassembled the electric motor, cleaned it all, and got it running separate from the solenoids and spool. I re-inserted the motor into the spool, and it would still run when "hotwired" (jump A to F1, power to F2, etc.). Then, once I reconnected the solenoid array and put it all back together, I connected the winch to power, just like normal and final installation. When doing this, the winch runs continuously, no matter what. It doesn't matter if I'm in free spool or engaged. I've heard about "welded solenoids," but I know little. Any ideas on how to fix this? (10 year old Warn xd9000i) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2015 Share Posted May 12, 2015 By the sounds of it, the solenoids are past their best. I'm be looking at replacing them with an Albright one instead. Quote Link to comment Share on other sites More sharing options...
zardos Posted May 12, 2015 Share Posted May 12, 2015 "welded solenoids" are where the powerful electric current used by winches has heated the terminals of the solenoid so much that they melt together (when welding the high current is intentionally used to melt the welding material and metal together, hence the term ).Solution is to replace the solenoids, but if you are in a jam when they weld then a sharp blow with a hammer to the solenoid might free them temporarily (if the have welded once the will probably weld again), but it might also destroy the solenoid but you have nothing really to loose when in a jam. Quote Link to comment Share on other sites More sharing options...
brokenthings Posted May 13, 2015 Author Share Posted May 13, 2015 Good and bad. Good: I fixed it. Bad: I had, in fact, wired it wrong and saw it when I used the Warn diagram. Stupid. Thank y'all for the gentle help. Quote Link to comment Share on other sites More sharing options...
