fuel tank
  • 1 month later...
the sender is PRC8463 early type? or AMR1495
gasket and union kit here, has all the bits you need, not convinced of the green composite washer though.
http://www.island-4x4.co.uk/fuel-tank-fitting-genuine-wfe000190kit-esr2000kit-nrc7570kit-p-6638.html
however also get a esr3278 and use some sealant or fibre washers on your pickup tube screws as the bearmach tanks don't use blind holes allowing the diesel to leak past the pickup tube
  • 2 weeks later...
 Share
