10digits Posted May 19, 2015 Share Posted May 19, 2015 I have installed a new Kenwood stereo in my '97 D1 4.0 V8. I bought a Metra adaptor kit (#70-9400) and it seems to have worked. Sort of. All speakers are working including subs in the rear but with the ignition on there is a loud ground hum. It also seems to be picking up the interference from the bluetooth. Has anyone else had a solution for this particular problem with aftermarket stereo replacements? If I need to run a new ground wire where should it run to and from? Quote Link to comment Share on other sites More sharing options...
steve_a Posted May 20, 2015 Share Posted May 20, 2015 If your car is fitted with an amplifier, I think if you have a woofer in the back door it's a cert, then the input is probably wanting line level feeds and the interference isn't a ground issue. Google line level converter to find one. My last 97 D1 had this. Quote Link to comment Share on other sites More sharing options...
