SHY 7G Posted May 20, 2015 Share Posted May 20, 2015 Hi All I have a new brake master cylinder and wondered if anyone would know what typical thread sizes outlets A and B (see photo) are? I can see that threaded outlet A is bigger than threaded outlet B. Would anyone also know which outlet supplies the front and which one supplies the rear brakes? thanks all. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 20, 2015 Share Posted May 20, 2015 What age? From ... maybe 1988 I think, they would be M10x1 and M12x1, brake stuff standardised around then. Take it to you local motor factors, they will have fittings on the shelf for you to make up pipes. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted May 20, 2015 Share Posted May 20, 2015 yup as Bowie69 says, M12 goes to front circuit M10 to rears 3/16" pipe for both. Quote Link to comment Share on other sites More sharing options...
SHY 7G Posted May 20, 2015 Author Share Posted May 20, 2015 My landy is a hybrid series 2a in the making, the master cylinder is new and I'm trying to source a set of banjo fittings for the front brake system line Quote Link to comment Share on other sites More sharing options...
western Posted May 20, 2015 Share Posted May 20, 2015 any motor factors should be able to sort some & suitable brake pipe to match. Quote Link to comment Share on other sites More sharing options...
western Posted May 20, 2015 Share Posted May 20, 2015 M12 x 1mm thread brake pipe end fittings for 3/16 pipe http://www.motorsport-tools.com/automec-brake-pipe-brass-union-fitting-male-m12x1mm-316-pipe.html M10 x 1mm for 3/16 pipe http://www.motorsport-tools.com/automec-brake-pipe-brass-union-fitting-male-m10x1mm-316-pipe.html Quote Link to comment Share on other sites More sharing options...
