GBMUD Posted May 20, 2015 Share Posted May 20, 2015 (edited) So, following yesterday's excitement at curing the vibration I now have a leaking transfer box. The input oil seal was new Contico yesterday. I am not 100% where the leak is, but this bolt has oil under the head as if oil is coming up the threads, does it go through the transfer case and into the sump, and should I therefor be sealing it?2005 Td5 R380/LT230 from a Disco1ThanksChris Edited to add - not a brilliant picture. That is from the front, the flange on the rear of the R380 and the front face of the transfer case. The transfer case sump is just visible at the lower left of the pic. Edited May 20, 2015 by GBMUD Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 20, 2015 Share Posted May 20, 2015 That bolt does go through into the casing and the hole is open into the cavity. Its easy to strip the thread on the casing for that one if you are too keen with the spanner! It looks wet above it though so my money would be on the intermediate shaft o ring (or the hole in which the IM shaft sits having elongated thus making it impossible for the o ring to seal) Quote Link to comment Share on other sites More sharing options...
GBMUD Posted May 21, 2015 Author Share Posted May 21, 2015 Thanks. Best see about sealing that and see if the leak persists. Do any/all other bolts do the same thing? Is there some recommended sealant? Hylomar, silicone...? Cheers Chris Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 21, 2015 Share Posted May 21, 2015 I used ptfe tape on mine (but mine still leaks from higher up). I don't think any of the other low bolts go into the cavity from memory. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 21, 2015 Share Posted May 21, 2015 This is the o ring fix: http://forums.lr4x4.com/index.php?showtopic=55338 Quote Link to comment Share on other sites More sharing options...
GBMUD Posted May 22, 2015 Author Share Posted May 22, 2015 I am rather hoping it is not O-ring related as removing the box again will not be any fun. Chris Quote Link to comment Share on other sites More sharing options...
