dangerous doug Posted May 23, 2015 Share Posted May 23, 2015 I took the tank off of my 110 today(93 200tdi) to fit the internal fuel pump but a lot of it disintegrated in my hands. After a major panic and a lot of swearing I came home and peroosed eBay for an alternative rust free one. My thoughts swayed to the td5 tank as I hear there is an internal pump in them but I found a steel one for a 110, like mine (only not ****) and noticed the hole in the top seems match the bolt pattern of the rangie fuel pump I have. Does anyone know if the rrc fuel pump will just drop in there? Or is that wishful thinking?? Quote Link to comment Share on other sites More sharing options...
greenstream Posted May 29, 2015 Share Posted May 29, 2015 Early 110 and Range Rover share the same tank. Try and dobbeltcheck at one of the dealer websites. Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2015 Share Posted May 29, 2015 200tdi doesn't have a 'in tank pump' as it's on the engine. Td5 tank won't fit because your chassis doesn't have the mounting points. the plate on top of the tank is for the spill return pipe, Quote Link to comment Share on other sites More sharing options...
tacr2man Posted May 29, 2015 Share Posted May 29, 2015 My 110 ( originally CSW V8) has a top mounted rangerover efi pump , and its acting as primary pump for diesel commonrail at the moment Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2015 Share Posted May 29, 2015 V8 has the in tank pump as at item 19 in http://lrcat.com/#31/4/53500 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted May 30, 2015 Author Share Posted May 30, 2015 Thanks for the replys, it's for my v8 conversion and I read the old ranges and defenders used the same tank so to confirm it I scraped off 20 years of silt and carp from the top of the tank to expose the bolt pattern to the sender. Looks like it's the same. I bought a new one for 80 posted and I'm going to fit it tomorrow. Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2015 Share Posted May 30, 2015 it's for my v8 conversion if you had given that bit of info in your first post, we would have known straight away. Quote Link to comment Share on other sites More sharing options...
