LSD different tyre size????
rrr47
 Share
I have a Range Rover Classic 1993 with the LSD mounted in the transfer box, (auto locking diff some may call it), can I run different tyre sizes on each axle?
235/70 x 16 fronts, 255/70 x 16 rears?
Will the LSD get confused and think the one axle is spinning?
Any help/advice much appreciated.
http://tire-size-conversion.com/tyre-size-calculator/
Use the comparison tool here
Basically there is a 4% difference which is not good add to that the front to rear wheel speed variance when turning a corner and the difference will be greater
Not a good idea in short
If you really want different size wheels try for something with a closer circumference
Would not recommend this at all on a standard landrover centre diff or the bronze / copper washers behind the centre diff gears won't last too long in my opinion
With an atb the gears may be forced into the pockets (locked application / locking using friction between the helical gears and the pocket recesses) more often so I guess over time the effectiveness of the atb may diminish)
Ian ashcroft should hopefully be along shortly (maybe next working week) to offer a yoda insight.
Or you could give him a bell for a chat
If you have abs on your vehicle there is an allowable rolling circumference difference before that goes haywire. Do a search for wabco habs d series manual I posted a few links to it on here regarding 3 amegoes etc (can't spell)
Rob
Thanks for all the input, I found two 235/70 x 16 Disco steel wheels with brand new Michelin tyres. Then two 255/70 x 16 tyres the same make and pattern, one on a steel Disco wheel, one wheeless, again brand new. All were very cheap.
Now I will either have to find two other 235s or 255s.
 Share
