ianmayco68 Posted May 25, 2015 Share Posted May 25, 2015 Hi, I am replacing the door pillars on my bulkhead and the feet at the bottom, I've fitted a complete new footwell but can anyone tell me or suggest a thread or tec article telling you the best way to get the inserted piece at the top out of the bulkhead without doing to much damage . cheers Ian Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 26, 2015 Share Posted May 26, 2015 "inserted piece at the top"... you might have clarify this a tad... picture would help. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 26, 2015 Author Share Posted May 26, 2015 Hi ,I've attached a photo below its the part of the door pillar that's behind the top door mounting holes . cheers Ian Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 26, 2015 Share Posted May 26, 2015 It will be held in place by some spot weld, you need to find them out then drill them with a special spot weld dril, that's how I'd go about it. You should be able to find the spots by the wee dimple they leave in the surface. I've had good experiences with these ones from eBay 160434407349. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 28, 2015 Author Share Posted May 28, 2015 Cheers Maverik, will have a look to see if I can find them. the ones I've brought arrived today (pic below) off ebay and they appear to be the same size as the outer part of the bulkhead as they are pressed out and have the hole for the wiring in, so am wondering if you cut thhole thing out and replace it with this cheers Ian Quote Link to comment Share on other sites More sharing options...
Early90 Posted May 28, 2015 Share Posted May 28, 2015 or cut the repair piece to fit? Quote Link to comment Share on other sites More sharing options...
Paul Brann Posted February 23, 2022 Share Posted February 23, 2022 On a similar topic, does anyone know the exact (!) distance between the centre lines of the big bolt mounting holes for the Defender door pillar/bulkhead feet . . . . I have a repaired one which seems to be 1497mm . . . odd that it's not 1500mm - oh! sorry - this is a Land Rover ! ! ! Just wondered if it had been bashed? Many thanks Paul Quote Link to comment Share on other sites More sharing options...
