marktdi Posted May 26, 2015 Share Posted May 26, 2015 Hi guys I have just changed the front axle on my 1991 200tdi 90 for one off a disco1 . One of the swivel balls on new axle is pitted . Will the ball off my old axle fit . Thanks for any help and info Quote Link to comment Share on other sites More sharing options...
SPendrey Posted May 26, 2015 Share Posted May 26, 2015 Can't tell you about whether it'll fit... but I can tell you the guide in the tech archive (here) was excellent for when I replaced mine. The only bit I didn't get was how many shims to use, and how to measure the steering resistance. I just put some on, tried it, then put some more on! I did mine without damaging brake pipes by using a spanner on the top swivel bolts and guessing the torque levels. Probably note recommended, but couldn't see any other way. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 26, 2015 Share Posted May 26, 2015 Depends on the age of the Disco axle, if early enough it might have the 'older' type of swivel ball with the railko bush at the top and taper roller bearing at the bottom. I believe Discos changed quite early on in their production run to the 'later' type with taper roller bearings top and bottom. Defenders didn't change until 1993/4 so you are after the older type. Quote Link to comment Share on other sites More sharing options...
duncmc Posted May 26, 2015 Share Posted May 26, 2015 I think the only real way to see if it fits is to take both apart and see if they are the same. Problem is that both could have been changed before, so you can't always go off the year of the car. Then there is there ABS/none ABS disco axles too. Quote Link to comment Share on other sites More sharing options...
marktdi Posted May 26, 2015 Author Share Posted May 26, 2015 The axle came off a 300tdi auto disco it has square steel bar across the bottom where the bottom pin is . The bar and bottom pin look to be held in with torx bolts rather than hex bolts . The axle fit fine and seems to run nice and smooth just a shame about pitted ball . Would be great if i could just swap one off my old axle with some new seals . Quote Link to comment Share on other sites More sharing options...
marktdi Posted May 26, 2015 Author Share Posted May 26, 2015 Just had a thought if i use one off my old axle with the pins ect from old axle then it would be ok ? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 26, 2015 Share Posted May 26, 2015 You'd have to use the whole swivel housing as well, as the housing needs to match the ball. Quote Link to comment Share on other sites More sharing options...
marktdi Posted May 27, 2015 Author Share Posted May 27, 2015 Thanks for the help guys I have ordered a complete swivel repair kit . Comes with new ball , bearings and all seals and gaskets Thanks again Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 27, 2015 Share Posted May 27, 2015 I hope it wasn't a Britpart one, if it is, you will find half the things don't fit, and the bearings are made of cheese. If a Bearmach item, then you are probably OK. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 27, 2015 Share Posted May 27, 2015 I hope it wasn't a Britpart one, if it is, you will find half the things don't fit, and the bearings are made of cheese. If a Bearmach item, then you are probably OK. Which balls are the ones that have been breaking? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 27, 2015 Share Posted May 27, 2015 Britpart IIRC. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 28, 2015 Share Posted May 28, 2015 I thought they all were breaking. Aftermarket and genuine. You can't really just say "Britpart" as I can guarantee all the aftermarket ones come from the same Chinese factory regardless of who sells it. Quote Link to comment Share on other sites More sharing options...
