110 middle row seat options?
Well, I started having a fiddle today with some freelander rear seats that I picked up for £10 on ebay. I will need to adapt the wheel arches a little.
These are just propped in place forward of where they will sit once fitted. They will probably move 3-4 inches further back once finished. Headroom wise, this is the height they will be at and that gives me a about three inches of headroom.
D13E4A33-F73E-4E67-A2EA-1C326B6FA222_zps
C2878213-8AAF-4313-BCA8-2BBAF2C7E146_zps
C2BDC149-2CE9-41C8-B459-0B8EB06778DC_zps
I'll update more as I go.
Hi
Just looking at your freelander seats in 2nd row.
I had some high backs fitted 7 years ago with a inertia seat belt for centre seat as I needed it for a baby seat.
Now kids are older and had a refurb on landy and they put a lap belt on as they said if an accident happened the floor mounted belt & inertia would cause terrible injuries and slip off shoulder & seat
( it did a few times if adults in back).
I really need a good seat belt and want to know if belts are ok from freelancer.
I was looking at fitting crew cab 60/40 with inbuilt belt.
Only other thing is fitting a rally style 4 point with straps either side of head rest.
Great examples of ingenuity ?
Hi,
I would post some pics if I could figure out how to? I could email you some?
mads
If you go to more reply options, you can upload the pics to the forum there.
Alternatively, use photobucket - upload the pics to their site and then you can get an image link that you copy and paste into your text on here. The image is then displayed in the post.
Hi
I think the middle seatbelt will work well with these freelander seats - the key to that one is making sure the seat is anchored sufficiently.
The outer belts will need to remain as the land rover ones, but I can feed the catch up through the plate in the bottom of the freelander seat and remove the original freelander belt catch. I dont think this will be a problem as it is essentially the same setup as the original seats really - uses the original inertia reels and the floor fixings in exactly the same way. Seat squab height is virtually identical to the old middle row in the pics above so this should be fine.
Also bear in mind the drivers side seat back catch is part of the seat belt arrangement.
Mike
In what way mike? It's not obvious to me how from memory (don't have the seats in front of me at the mo!)
If you look at the car side of the catch you'll see it has a stay that bolts to the body as well as the catch loop. The passenger side doesn't have this. If you think about it the shoulder strap is mounted to the seat in the middle therefore in an accident the top of the seat will take the force of the middle passenger. I'll take a pic of mine later.
Mike
..I think I made it!! :)
The seats are in the front bolted through the seatbase into a new support again bolted to the U shaped support from the chassis. Beside the door it is bolted through the floor/wheelbox with a spreaderplate on the backside. In the middle it is bolted through the floor onto a new support welded to the Aframe out...inrigger? -part of the chassis. Both parts of the seat can be folded down and when so, it equals the height of the wheelboxes.
Mads
Mads
Good job. They look neat and fold down in a sensible manner too so that they make the most of the available space.
Mike
A pic would be good Mike - I looked at mine this morning, but i cant quite make out what you mean. I have the brackets that the seat back attaches to and they each have an arm on that attaches to the vehicle side - i plan to use this (although may have to modify it if thats what you mean? (not sure it is as you said it was only the drivers side)
Some progress today. Some pics.
Mark wheel boxes to cut.
CD414701-ED7A-44FC-B126-0065E6F963AA_zps
93E62FAE-0472-4303-8D7F-27CC7D888C4A_zps
Then cut the holes on both sides
282B5784-653C-40C2-8007-62B10CC99098_zps
B599A197-328B-44D3-ABF6-F05F54F51AC4_zps
Check fit
DF14F8F0-BC92-4A6B-BCB0-2A73EDE9A9A4_zps
8E7CB498-6FC6-41AF-BD64-8DF59E18269E_zps
Then a bit of CAD (borrowed from the fellas on project binky)
7C1EC8D4-629C-4202-A3C1-10F696C91BCA_zps
86CD34D6-DF03-495C-BD61-2ADFE1D003F1_zps
Make it into something metal
5F58D6FE-7753-444B-ABB7-F19EFBB5B302_zps
B6CD0238-BB8E-4015-9945-B9C21CD5E815_zps
B77BBD23-A3EC-4BD5-8F55-D173D3998147_zps
Next were the brackets to hold the seat crossbars. I didn't want to skimp here so they're 25x50x3 RHS.
E374FAD4-F957-4D0D-9AA7-C9A582244502_zps
83DB80D0-D36C-4DFD-9512-51ABFD557E74_zps
Do this all twice and then start fixing bits in place
C4C7CB31-FFDB-466A-83DB-35BD51114CBD_zps
9C4A8594-3175-42A6-B17D-6EDB0DAB7C5C_zps
49F6F56F-75FA-4D18-8997-41E680DFA0B5_zps
Cut the cross bar. This took some fiddling to get the height right as the outer 'feet' of the seats sit on the alli I've filled the wheel box cut outs with and the seat brackets sit 1/2 inch lower than these. And then test fit
2A4AF015-70BA-4FE8-8FA0-B38FFF9970D7_zps
41A00AF8-1C2D-4ECA-BFD9-E4184DB0DF4C_zps
The blocks of wood holding the front of the seat aren't permanent. Need to make the front crossbar now and then secure the seatbacks. The frame needs taking out and the crossbar welding up fully, then a coat of paint. But getting there
might be possible to reuse the old seats lower pivot brackets, just move them to the required location, they only bolt to the heelboard.
neat work on the arch recess cut & fill panels & rear base supports.
Thanks! That's what I plan Ralph with the lower pivots. They are in the right place so no need to move them. I will use all four and then create four legs that raise up to a crossbar that the seat brackets will bolt to.
  • Like 1
Thanks Mo
Quick question for those following..... I was planning on fabricating and bolting the front mount to the existing seat brackets on the heel box. This would allow both the freelander seat attachment to the frame, and the frame attachment to the heel box to pivot. Is this likely to be sturdy enough or should the frame be static and the only pivot point be the hinges that attach to the seat itself?
I was wondering about that Mike. I just keep thinking of the forces that would go through the frame if there was to be an accident with someone belted into the middle seat, so i guess too many pivot points would be a bad thing in this instance. The original seats wouldn't have had this problem as the seatbelt and catch were attached to the floor of the vehicle, not the seat. Perhaps it would be better not to use the 3 point harness in the centre of the freelander seat and to utilise the original lap belt?? That way no force goes through the seat in the event of hard forward braking??
Any thoughts on this bit guys - i'd appreciate your ideas.
Bit more progress. I decided the original mounts would be fine. I have an eberspacher in the way that was making other solutions difficult and the heaters position is spot on where it is.
So, front frame built tonight. I've opted to use only the rear most bolt holes on the Freelander seat brackets (will post a pic tomorrow when they are fitted to see if you think this is ok)
Pics of the front frame-
BFC9D0C9-F4F3-43B6-8BC0-B22C9CD293AF_zps
0A8AB50B-BD87-4C51-8862-7689DE614932_zps
D662D59F-72DB-482A-8D2C-D4F0603C3158_zps
All the metalwork is in the garage now having had a coat of paint. Seat back mounts tomorrow (along with fpr on the disco and welding on the disco chassis :( )
Ok. The seats are in. First mounted the seats to the front bar.
D1DC09D7-22C3-4CA5-8235-C6B10F600046_zps
AF264ACC-45F6-452F-8A69-547C29D20BA7_zps
Now, I've only used the rear bolt holes for the seats. Do we think this is ok? I couldn't see any advantage to making brackets to mount the front holes to the crossbar.
ED184042-4DA4-4463-968F-AA48F054FDB0_zps
You can see the front brackets better here
67FA756E-E393-426C-8B46-ED4214B5BA55_zps
Just enough clearance above the eberspacher!
023554A8-7A24-4FDB-A690-E042D398E66A_zps
(It's more than it looks in the photo)
Now, these rear brackets made me ponder! They fix into the seatback to lock it in place.
EFF4FA79-B8C0-4749-AC43-44020CEE80A7_zps
Trouble is, in the Freelander they're bolted through behind the c pillar so the don't fit all the way into the seat as they sit removed from the parent car. This is one locked in place
AD5026BE-C278-4143-B113-B206D611292A_zps
So. Knocked up a bracket
9BE2FCDD-A528-4282-88D2-59E7C1FD1EE4_zps
7FB36AE9-C423-46F5-A445-B8ED5A04FAD7_zps
Then they fit
32FD20FA-13B5-4723-A9E2-14CE166ABE91_zps
Next was where to fit the end of the arm. These are a pain as they actually block a lot of space. I settled on this
0A0D05FA-A346-4A6D-B308-6EB39AC79047_zps
5774BE8E-25F2-47E0-9489-CA8391156BD7_zps
Then repeated for the other side. I was a bit worried this wasn't sturdy enough, but once bolted in, the seatback cannot move and the tie bar is rigid. I think this setup leaves me enough room to fit a two seat bench seat instead of the three seat that was fitted. I may not bother, but as occasional seats, they are useful.
Brackets just getting a final coat of paint, then bolt them in tomorrow.
