defender dinky Posted June 1, 2015 Share Posted June 1, 2015 hi, is a double cab pick up made up of different defenders or one on its own, dd Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 1, 2015 Share Posted June 1, 2015 I'm not sure I understand exactly what you mean, but the double cab pickup (dcpu) is an actual model. Quote Link to comment Share on other sites More sharing options...
muddy Posted June 1, 2015 Share Posted June 1, 2015 The 127/130 model has been available since ~1985 and is as standard a double cab with hi-capacity rear pickup body, the 110 was available from ~1998 as a double cab pickup however the load bay is actually shorter than a 90. You can bolt a double cab roof ( all the same size) onto a truck cab rear section ( also all the same size) and plonk it on a 110 sw/csw the only problem being the rearmost bulkhead in the front of the tub or lack of it in a sw/csw as the case is, you could either source a factory DC tub, fabricate a lower bulkhead or un pick the bulkhead from a non sw/csw tub and weld it into your tub. Hope that makes sence. Will. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted June 2, 2015 Author Share Posted June 2, 2015 I understand it thks for info dd Quote Link to comment Share on other sites More sharing options...
