ronnie_rotten Posted June 4, 2015 Share Posted June 4, 2015 So i should be glad they swish swash at all right?!? The intermittent setting is the same as the normal speed wipe and when you cancel the wiper lever the blades stop exactly where they are instead of returning to the bottom of the screen. Any ideas? Flat carburettor? Renegade ecu? Moaning about nothing? Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 4, 2015 Share Posted June 4, 2015 Motor park switch duff... needs replacing I'd say... http://www.ebay.co.uk/itm/270452504410?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 4, 2015 Share Posted June 4, 2015 I'd concur, there's even an how-to in the tech archive. ? Mo Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted June 4, 2015 Author Share Posted June 4, 2015 You guys. I'm not even gonna bother getting a Haynes manual! I have an old indicator/wiper unit, can I pillage the switch from there? It's from an 85 defender. Will that work in a td5? Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 4, 2015 Share Posted June 4, 2015 I think the old park switch in theory would work. I think the difference between tdi and td5 lies in the gear more than the park switch. However I would buy a new one. They aren't expensive, and who knows, the old one might work for a month then pack in as well.. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 4, 2015 Share Posted June 4, 2015 The park switch is on the motor in the dash - rather than the stalk ... Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 4, 2015 Share Posted June 4, 2015 Who said it was in the stalk? Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2015 Share Posted June 4, 2015 You guys. I'm not even gonna bother getting a Haynes manual! I have an old indicator/wiper unit, can I pillage the switch from there? It's from an 85 defender. Will that work in a td5? pre 300tdi stalk isn't wired to run the intermittent wash/wipe settings, I had to replace the stalk in my '89 110 to get the intermittent working as it should, old stalks have a down press 'flick' wipe. Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 4, 2015 Share Posted June 4, 2015 I see what you fellas mean about the stalk now. He was talking about using an old one... Doi..... Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted June 4, 2015 Author Share Posted June 4, 2015 Right, I'm catching on now! I imagined that switch being at the stalk, hence thinking I might cannibalise one to fix the other- not gonna work in this case! I'll have to see about getting a new one ordered. I was kind of hoping (as with the last 4 jobs that needed doing) I could just wander into the 'parts department', fish around for 5 minutes, then emerge with the part I needed. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted June 4, 2015 Author Share Posted June 4, 2015 pre 300tdi stalk isn't wired to run the intermittent wash/wipe settings, I had to replace the stalk in my '89 110 to get the intermittent working as it should, old stalks have a down press 'flick' wipe. Would another option be to fit the whole older unit and avail of the flick swipe instead of the intermittent setting? I could live with a sprung lever better than the setup as it is. Easier to manually park the blades that way at least. Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2015 Share Posted June 4, 2015 the flick wipe still needs a fully operating wiper motor park switch to park the blades correctly, it's easier to just fit a new park switch to the motor. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 4, 2015 Share Posted June 4, 2015 Intermittent came in at least for 200Tdi, think it was around the turn of the 90s some time. My 1992 and 1993 models have both had it. They have flick-wipe too, you just push the stalk up towards normal speed enough to engage a sweep but not enough to flick over into the normal speed position. Not as easy as just pushing down against a spring no, but you get quite proficient at it Quote Link to comment Share on other sites More sharing options...
