=jon= Posted June 5, 2015 Share Posted June 5, 2015 Hi, My '92 110 CSW has had fixed side windows fitted - looking at the codes on the glass it appears to have been factory fitted as they match with the other windows... The seals are getting a bit tatty - I've had a quick look at replacements but I'm not sure which ones are right... Looking around turns up: http://www.lrseries.com/shop/product/listing/17466/2919/304235-HARD-TOP-FIXED-WINDOW-RUBBER-SEAL.html Which lists for early defenders, this: http://www.lrseries.com/shop/product/listing/471/2919/302177-WEATHER-STRIP-FIXED-WINDOW.html Which is in 1M lengths.. Reading around it's suggested that the seals are the same as for the rear safari windows - is it possible to buy this in long lengths so I can cut it down to fit? Thanks! Jon Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2015 Share Posted June 5, 2015 have a look on http://www.woolies-trim.co.uk/c-122-screen-section.aspx you'll need to know how thick the glass is to most early 90/110 have 5mm glass, later use 4mm. Quote Link to comment Share on other sites More sharing options...
=jon= Posted June 5, 2015 Author Share Posted June 5, 2015 Thanks - much appreciated! If the swap over point was around '87 when they changed to the defender branding I guess mine will be 4mm Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2015 Share Posted June 5, 2015 I believe that's right, my 110CSW is a '89 it has 4mm glass. must replace the alpine window seals on mine too. Quote Link to comment Share on other sites More sharing options...
