RodneyA Posted June 6, 2015 Share Posted June 6, 2015 A quick wee Q, I've broken one of the sump bolts on my 200tdi. Do I need to remove the ladder frame and get it fixed or will the sump be fine with just 1 missing bolt. It's one of the shorter bolts on the side. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2015 Share Posted June 6, 2015 ladder frame can only be removed after the complete engine is removed from vehicle, may be possible to drill the remains of the snapped bolt & extract with a easy-out or using a left hand twist drill bit, Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 6, 2015 Share Posted June 6, 2015 Just the one bolt won't make much difference. Just make sure that RTV squeezes out where the broken bolt is, and put a blob in the hole as well. As long as the surfaces are clean and dry there should be a decent seal once the sealant is cured. Les. Quote Link to comment Share on other sites More sharing options...
