pete3000 Posted June 8, 2015 Share Posted June 8, 2015 Technically LR related as I wanted to know is there a quick reference calculator or sheet, which would tell me what size OD steel tube I would need for a given bolt size. I'm thinking specifically for crush tubes, but other projects looming. Brackets etc. i.e if you have an M10 bolt and want a sleeve to weld into a box section, then you need clearance but not masses. I'm sure it's not as simple as 2mm wall x2 =4mm wall +10mm = 14mm OD tube 2mm wall. (is it?) Pete Quote Link to comment Share on other sites More sharing options...
Edlen Posted June 8, 2015 Share Posted June 8, 2015 Is this any help? http://www.engineeringtoolbox.com/bs1387-steel-tubes-dimensions-d_97.html Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 8, 2015 Share Posted June 8, 2015 use a 1/2" bsp tube, gives you a bit of space around the M10 bolt to save it seizing, unless of course you're trying to use the bolt as a location dowel as well Quote Link to comment Share on other sites More sharing options...
