More Power from an L10
was a nice truck?
 Share
Most L10s have got top-stop injectors in a fuel filled head.They rely on the cam to operate a pushrod that works a needle in the injector.The fueling can be increased by putting more preload on the pushrod.But it isnt recommended unless you are sure you know what you are doing,cos if you go too far the needle will punch through the bottom of the injector :o
Paul ;)
 Share
