boaterboy Posted June 10, 2015 Share Posted June 10, 2015 I would be grateful for help in identifying where on the steering box is the bleed nipple that I've heard reference to. How is it best accessed, please? Socket size? I guess one is working blind? Is the system bled with the engine running? All help will be gratefully received. Thank you. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 10, 2015 Share Posted June 10, 2015 You don't really need to bleed the system. Turn the steering to full lock and hold it there for a few seconds, then turn to opposite lock and hold it again for a few seconds. Because the system is both high and low pressure it should bleed itself. If you are unsuccessful, then bleeding is done inside the wheel arch with the plastic cover removed and with the engine running. Les. Quote Link to comment Share on other sites More sharing options...
boaterboy Posted June 12, 2015 Author Share Posted June 12, 2015 Thank you, Les, I'll follow your advice. Quote Link to comment Share on other sites More sharing options...
