xychix Posted June 12, 2015 Share Posted June 12, 2015 I'm looking for a list of part & partnumbers to do a round of simple maintenance. What I'll buy without numbers: - Engine oil (15w40) - gearbox, reductionbox, axle oil (80W90 approx 10L should do) What I need numbers for / have numbers for: - diesel filter (RTC6079) - airfilter (Currently I have the oil bath one, a suiltable paper filter number is also welcome) - oil filter - sump plug - sump plug seal - .... ? What I do / have done seperate from basic maintenance: - everything that seems broken leaking or otherwise. (eg. electrical issues, leaking clutch hose, leaking hub seal) What basic maintenance am I missing? Quote Link to comment Share on other sites More sharing options...
discomikey Posted June 12, 2015 Share Posted June 12, 2015 Grease the props haft uj's and slip joints. Diff oils are 80w90 as well, you should check and adjust the brakes and handbrakes replacing shoes and drums if necessary. I wouldn't just replace the sump plug and seal as a matter of course, I would replace the copper washer (seal) the first time and then every 3-5 services after that. Unless the actual plug is damaged In the link below you will find a series 3 parts catalogue in PDF, you may find this useful during your ownership Quote Link to comment Share on other sites More sharing options...
discomikey Posted June 12, 2015 Share Posted June 12, 2015 http://www.landroverweb.com/landrover/pdf-land-rover-manuals/ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 12, 2015 Share Posted June 12, 2015 Oil & grease points for info: Quote Link to comment Share on other sites More sharing options...
xychix Posted June 12, 2015 Author Share Posted June 12, 2015 does anyone have partnumbers for: - diesel filter (RTC6079) - airfilter (Currently I have the oil bath one, a suiltable paper filter number is also welcome) - oil filter - sump plug - sump plug seal - .... ? Quote Link to comment Share on other sites More sharing options...
