dangerous doug Posted June 13, 2015 Share Posted June 13, 2015 Can anyone advise the best place to take the 12v switched live from please. I'm putting a 3.9 in a 110 200tdi Quote Link to comment Share on other sites More sharing options...
=jon= Posted June 13, 2015 Share Posted June 13, 2015 Mine's straight off the back of the ignition switch... Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 13, 2015 Author Share Posted June 13, 2015 As simple as that? Thanks Jon Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 13, 2015 Share Posted June 13, 2015 Yup, exactly Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 13, 2015 Author Share Posted June 13, 2015 I was staring at the diagram thinking it can't be that simple lol Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 15, 2015 Share Posted June 15, 2015 Via a fuse, naturally. Bear in mind the ECU itself only takes about 1A although the ground-return current through it (from injectors) is much higher, 5-10A. So a low-value (3A) fuse on the +12v feed to the ECU but good solid ground wires. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 15, 2015 Author Share Posted June 15, 2015 Thanks for that, I do have some inline micro fuse holders ready to solder in Quote Link to comment Share on other sites More sharing options...
