multiple horns
Hi there are two horns on the list of my td5 defender. I'm thinking that one might be aftermarket from a po.
That one has spade connection. Not a plug. And a gay sound.
The horn switch inside the car uses only that horn. When the car is locked with a door open that horn and the other horn both double beep.
That double horn sound is louder so I tried to connect the two wires to both horns so that the two horn tone is heard when I use the switch inside. I joined the wires and all was good. I then mounted the horns back to where they were and there seems to a problem.
Like I said all was well before I mounted them.
I now have no horn sounds at all when I push the button on the stalk or when I lock the door with one open.
Can anyone help me?
