sixfeetofmud Posted June 23, 2015 Share Posted June 23, 2015 Got a swivel from a early disco and everything fits good except the top swivel pin looks different for a abs sensor I believe . can I just use the defender swivel pin instead . it looks different . Quote Link to comment Share on other sites More sharing options...
sixfeetofmud Posted June 23, 2015 Author Share Posted June 23, 2015 Quote Link to comment Share on other sites More sharing options...
sixfeetofmud Posted June 23, 2015 Author Share Posted June 23, 2015 So opened it up looks like its a different set up ? Thrust bearings instead of tapers ? Why is this different ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2015 Share Posted June 23, 2015 Disco went to taper... they just did, pretty sure defender stayed Railko bushing for a while after. What age Defender? Quote Link to comment Share on other sites More sharing options...
sixfeetofmud Posted June 23, 2015 Author Share Posted June 23, 2015 Its a 97 TDI and the swivel and housing is from a 98 disco Quote Link to comment Share on other sites More sharing options...
sixfeetofmud Posted June 23, 2015 Author Share Posted June 23, 2015 The defender one I took off is taper on both sides . the new disco one is the other type I guess . Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2015 Share Posted June 23, 2015 Just looked, no, you can't mix and match, you need to use the pin with the swivel it is designed for. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted June 25, 2015 Share Posted June 25, 2015 Just replaced n/s swivel on my 95 300tdi that was taper. Not sure if they are interchangeable check the specs for both swivels or measure with micrometer if you have one. If they match just drift out old races and buy set of new pins top and bottom with matched races for a taper roller set up. Just thinking off top of my head maybe railko was used to allow for abs sensor set up on the disco don't have enough knowledge to know if there is a taper roller set up for the top pin which accomodates an abs. Ian Quote Link to comment Share on other sites More sharing options...
