Bomag Posted November 14, 2006 Share Posted November 14, 2006 There are two electric sensors on the top of the water pump housing (where the radiator top hose fits) Any idea what these are for? Are they a cold start sensor or for a fan? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2006 Share Posted November 14, 2006 Got a piccy? Carb or EFi? Quote Link to comment Share on other sites More sharing options...
Ivan Posted November 15, 2006 Share Posted November 15, 2006 As FF says Carb or EFI ? If EFI it's possible one is the temp sensor and the other one is to cut in the aircon fans if the temp gets too hot. Ivan Quote Link to comment Share on other sites More sharing options...
Bomag Posted November 15, 2006 Author Share Posted November 15, 2006 As FF says Carb or EFI ? If EFI it's possible one is the temp sensor and the other one is to cut in the aircon fans if the temp gets too hot.Ivan Its carb. To my knowledge the SD1 didnt come with EFi, but I could be wrong!!! Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 15, 2006 Share Posted November 15, 2006 wasn't the vitesse fuel injection? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 15, 2006 Share Posted November 15, 2006 Some were even twin-plenum I believe Quote Link to comment Share on other sites More sharing options...
minivin Posted November 15, 2006 Share Posted November 15, 2006 Some were even twin-plenum I believe Oh yes indeed, ask Rogue Trooper as he knows a little about it Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted November 15, 2006 Share Posted November 15, 2006 Vitesse and Vanden Plas were both efi, rated at 190bhp. Larger valves, hotter cam and large bore exhaust, along with Lucas flapper. Comfortably did 140mph, I put one of these engines in a Crew Cab Sherpa(tipper) and used it for work , it was taken out to 3.9 and had a 2.5 inch straight through exhaust. Sounded fab went like stink, drive every where in 5th gear, needed a much higher final drive though, used to rev out at 90mph . Happy times Quote Link to comment Share on other sites More sharing options...
