mrfish Posted July 3, 2015 Share Posted July 3, 2015 After 5 years of trying to work out where the annoying rattle is on the 110 i have finally found it. The caliper in the X-Brake seems to be rattling. What is the best solution? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 3, 2015 Share Posted July 3, 2015 It will be the pads rattling where they have come loose. There is a rebuild kit available, isn't too difficult to strip the caliper down and rebuild it - glueing the pads in nice and tight to try and prevent re-occurrence. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 3, 2015 Share Posted July 3, 2015 Where's the rebuild kit from James? I'm after the plastic bush bit that seals the pivot, and the 4 orings that go into the casting where the two plastic bushes run. Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2015 Share Posted July 3, 2015 Where's the rebuild kit from James? I'm after the plastic bush bit that seals the pivot, and the 4 orings that go into the casting where the two plastic bushes run. Foundry 4x4 have X-Eng's product supply now X-Brake pads http://foundry4x4.co.uk/index.php?route=product/manufacturer/info&manufacturer_id=14 X-brake caliper repair kit http://foundry4x4.co.uk/index.php?route=product/product&manufacturer_id=14&product_id=272 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 3, 2015 Share Posted July 3, 2015 The fitting instructions have a section on stopping the pad rattle. The PDFs will be on foundary's site. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 4, 2015 Share Posted July 4, 2015 Thanks Ralph, I couldn't find that when I looked on there the other day. 1 Quote Link to comment Share on other sites More sharing options...
mrfish Posted July 5, 2015 Author Share Posted July 5, 2015 Thanks guys. I have found the relevant pdf and will follow the instructions given and see if that helps. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 5, 2015 Share Posted July 5, 2015 It did for me ! Quote Link to comment Share on other sites More sharing options...
