pete3000 42 Posted November 24, 2015 Share Posted November 24, 2015 Which springs do you have FF? I am running britpart (don't start)....... yellow (painted black) HD DA4208 +40mm at the back with LR oem wolf hd front drivers side springs x2 at the front. Ride is rock hard at back, but needs these for the 500kgs+ of load some of which is in the wolf roll cage (nice and high), squashes most of the 40mm back down with a full load on. Quote Link to post Share on other sites
FridgeFreezer 2,055 Posted November 24, 2015 Share Posted November 24, 2015 According to the previous owner: The springs on there are ANR3540 rated at 8055kg, Green/pink markings. They are very OTT though, we put (literally) a ton of tools & gear in the back when clearing the garage out and it hardly budged on the springs but rode much better once we've tucked up the various other jobs on it we'll weight it on a weighbridge front & rear and work out what it actually needs. I suspect your shtpart ones are just really stiff, that's how they usually achieve cheap lift, and it won't be doing you any favours. Properly rated standard-height springs would likely fare much better. You assume you need very heavy springs but how much does the ar5e of an unladen Pulse ambulance really weigh? I'd guess whatever they had as standard when in service would be plenty, as they would've been rated for carrying people & medical kit etc. across rough terrain. Quote Link to post Share on other sites
elbekko 378 Posted November 24, 2015 Share Posted November 24, 2015 Sounds like you would be better off with air suspension. Quote Link to post Share on other sites
Eightpot 228 Posted November 25, 2015 Share Posted November 25, 2015 My Range Rover ambulance would roll stupidly on bends, sproinging about like a jack in the box. For the Africa trip I swapped the springs for the heaviest duty OME (as a Rangie it has the narrow rear springs, had to get the very heaviest duty disco springs). On-road handling transformed, even though it was raised nearly 2" also. It could also handle serious extra weight, and rides much nicer with it. However, I wouldn't go this route again. Off road was ok, but travelling on corrugated roads was painfully jarring and ended up doing damage to the chassis (cracked it). In future I'll put up with a bit of roll in favour of a smoother ride on ragged roads. Best way to minimise the roll is get all the weight down low in the first place. Carry less beer. Ha ha. Quote Link to post Share on other sites
FridgeFreezer 2,055 Posted November 25, 2015 Share Posted November 25, 2015 ended up doing damage to the chassis (cracked it). Yep, that's definitely worse than body roll! Good example of the law of unintended consequences when deviating from OE too. Quote Link to post Share on other sites
Popular Post Ian_Fearn 48 Posted November 29, 2015 Popular Post Share Posted November 29, 2015 Neill, can you tell me what the unladen weight of yours is (i seem to remember yours might be a bit heavier than mine)? I don't need it for registration, i'm just interested to know what sort of payload i'm going to have. I'll take it to a weighbridge once its registered and the nasty weather is over with! Cheers, Ian 6 Quote Link to post Share on other sites
tweetyduck 67 Posted November 29, 2015 Author Share Posted November 29, 2015 it was 2660kg on the brake testing machine with half of the stretcher kit removed. I left one side in to show a bed if they got stroppy registering it. The GVW is 3800 on mine;. Quote Link to post Share on other sites
tweetyduck 67 Posted November 29, 2015 Author Share Posted November 29, 2015 I jsut sold all the Ali for £35 at the scrap place. I should have got £60 but half was "contaminated" with some rivnuts and a few hinges. So make sure its all drilled out if you take it. I got 45p / kg for clean and only 17p/ kg for the mixed and i thought i'd got it all. So even one rivnut and they marked it as mixed. I could not be bothered to take it back and drill them out. Theres approx 150kg of beds in just metal. the headrests and belts and stuff are extra. I rekon at least another 100kg. Quote Link to post Share on other sites
Ian_Fearn 48 Posted November 29, 2015 Share Posted November 29, 2015 Cheers Neill. So best case scenario i've got 1000kgs to play with, worst case ~800kgs. I still plan to raise the roof on mine so i've got a little weight in the extra framework but using Alu should keep the weight down. I think the biggest challenge is to try and retain the aesthetics. Replacing the edge sections with like for like will be impossible unless I can find somebody scrapping a body. Do you have any pictures of your conversion so far? Just incase anybody else needs one, the V55/5 came through in 4 days. I ordered one on-line and another through the call centre on the same day. Both came on friday. Quote Link to post Share on other sites
bobtail4x4 1 Posted December 1, 2015 Share Posted December 1, 2015 thinking of fitting deep dish alloys ( I have a set) to my 130 ambulance, but cant find a yea or ney, on loading. Quote Link to post Share on other sites
FridgeFreezer 2,055 Posted December 1, 2015 Share Posted December 1, 2015 I doubt there's many alloys that are officially load rated for the ambulance (or high-cap pickup), especially aftermarket ones. The parts book (or the good denizens of the part numbers forum) should tell you what's allowed from the parts bin. Quote Link to post Share on other sites
bobtail4x4 1 Posted December 1, 2015 Share Posted December 1, 2015 poo Quote Link to post Share on other sites
tweetyduck 67 Posted December 1, 2015 Author Share Posted December 1, 2015 maybe theses? http://www.mod-sales.com/auction/vehicle/related/62856/5_x_WMIK_Rims.htm Check the rating. I've not. Quote Link to post Share on other sites
tweetyduck 67 Posted December 1, 2015 Author Share Posted December 1, 2015 The put them on a 4.7 tonne armpured so they should be enough. Get em sprayed. I think there are some 1.5T "blindo" wheels but consider wolfs are 2.2T. I belive the WMIK rims are 1.55T each but info is scetchy. Do your homework before purchase. Quote Link to post Share on other sites
FridgeFreezer 2,055 Posted December 2, 2015 Share Posted December 2, 2015 Wolf rims look quite smart and they're ~£50 a rim brand new genuine parts: Quote Link to post Share on other sites
bobtail4x4 1 Posted December 2, 2015 Share Posted December 2, 2015 its got Wolf rims now, anyway its up and running on 12v today, next step MOT and register. anyone know the value of the 24v bits removed? Quote Link to post Share on other sites
tweetyduck 67 Posted December 2, 2015 Author Share Posted December 2, 2015 I don;t know but if they fit a 300Tdi i might be interested...... I'm also interested in a single genuinewolf rim. Quote Link to post Share on other sites
bobtail4x4 1 Posted December 3, 2015 Share Posted December 3, 2015 I don;t know but if they fit a 300Tdi i might be interested...... I'm also interested in a single genuinewolf rim. they are off a 300tdi, I only have the 5 wheels Quote Link to post Share on other sites
tweetyduck 67 Posted December 3, 2015 Author Share Posted December 3, 2015 they are off a 300tdi, I only have the 5 wheels So what you got thats 24v...Starter, Alternator? Relays and stuff? I'm interested if they are working. I'd need photos and numbers off them so i can check they are good for me. Also one wheel. Quote Link to post Share on other sites
bobtail4x4 1 Posted December 3, 2015 Share Posted December 3, 2015 all were on the truck and working, its now 12v so everything is spare, will take photos for you. Quote Link to post Share on other sites
Ian_Fearn 48 Posted December 8, 2015 Share Posted December 8, 2015 My V5 came through today, 1 week to the day after posting it. Thanks for your help Neill. Bobtail, can you tell me what you've done to convert to 12v? I want to do the same. 1 Quote Link to post Share on other sites
bobtail4x4 1 Posted December 8, 2015 Share Posted December 8, 2015 basically I gave it to a mate, LMAO, he swapped everything over, alternator,starter,wiper motor, glow plugs and relay, fan motor, fuel solenoid, plus bulbs and a fair bit more, Quote Link to post Share on other sites
Happyoldgit 675 Posted December 8, 2015 Share Posted December 8, 2015 I hate this thread I've had a Wolf ambulance itch that's needed scratching ever since I sold the Locomotors 127 that I converted some years back! 1 Quote Link to post Share on other sites
bobtail4x4 1 Posted December 8, 2015 Share Posted December 8, 2015 I can send you photos Steve Quote Link to post Share on other sites
Ian_Fearn 48 Posted December 15, 2015 Share Posted December 15, 2015 Neill, I think it was you that mentioned you'd got insurance through Heritage? Did you take out their breakdown cover? Quote Link to post Share on other sites
