Maverik Posted July 10, 2015 Share Posted July 10, 2015 Hi guys, Having a mental block moment. and need some help with 4x4 recovery type winch brakes. I've got a Chinese 12000lb recovery winch that looks a bit like this one : http://www.ebay.co.uk/itm/Wo-12000LB-Electric-Recovery-Winch-Universal-DC12V-24V-Steel-Cable-Rope-Towing-/121668251021?pt=LH_DefaultDomain_3&hash=item1c53fe2d8d It came with my truck. So I dismantled it to give it a clean and see if it was serviceable, its got a basic brake that actuates onto the inside of the drum, can someone tell me what is the purpose of the brake and when it actuates... I have a feeling mine isn't working properly, and my brain isn't being all that helpful today... I winched the truck up a slight slope to pretension the rope on the drum, when I stopped the winch at any time, the vehicle bounced a little on the rope, and every time it bounced there was a nasty clicking noise, which I imagined at being a gear jumping... should the brake be doing something here or is the gearbox fubar... The winch had been abused before I got it, now just working out if its worth me just swapping out the gearbox for a cheap quick fix otherwise investing in a new winch. Cheers Mav Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2015 Share Posted July 10, 2015 Clicking is probably the brake engaging, if it wasn't working it would pay out when you turn the winch off after winching up a hill. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 10, 2015 Share Posted July 10, 2015 What Bowie says. the clicking is probably the brake gripping. The brake should be on whenever the winch is NOT being powered in either direction. So if you've winched up a hill, you shouldn't start rolling back down when the winch is stopped. Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 10, 2015 Share Posted July 10, 2015 and it obviously helps you stop when winching down hill. The brake does make a clicking/slipping gear noise which is quite alarming the first time you hear it. My TDS goldfish makes that noise. Its hardly ever used, so i doubt its a problem however i have no idea if its meant to make that noise or not haha. no doubt someone with more winching experience will be along to enlighten us shortly Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 10, 2015 Author Share Posted July 10, 2015 ok, got you. thanks for that chaps. Hmm still sceptical the brake is able to make such a noise. The brake must lock the drive shaft to the winch drum stopping it, in which case if the drum is still moving something in the gearbox is jumping... Hmm will need to do some more testing. Quote Link to comment Share on other sites More sharing options...
