white90 Posted September 11, 2005 Share Posted September 11, 2005 I'm adding a nother fuse box to supply the heated seats/rear charging sockets plus expansion for future any tips? I have purchased a fuse box and intend to run a decent size cable to the fuse box on the bulkhead behind the passenger seat then wire one side of the fuse box in series so I can feed the new items from the other side once fuses are installed. this will let me tidy the wiring currently in place and have less connections on the battery itself. the charging will have independant switching the heated seat are already installed/working so it will just be a re routing of the wiring. I'll do some pics as I go. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 11, 2005 Share Posted September 11, 2005 Tony, Make sure you fuse the new feed to the fuse box with a 40-60 Amps fuse mounted close to the battery ! not.... a granny sucking eggs comment Quote Link to comment Share on other sites More sharing options...
white90 Posted September 11, 2005 Author Share Posted September 11, 2005 Can't I make fuse 1 the 40amp then extend the other side in series to provide the power for the other ccts? Quote Link to comment Share on other sites More sharing options...
western Posted September 11, 2005 Share Posted September 11, 2005 (edited) You could, but the cable run from the battery +ve terminal to the fusebox will be unproteced better to protect as much wiring as possible, I must add an additional fusebox to my 110 for my ham radios. Edited September 11, 2005 by western Quote Link to comment Share on other sites More sharing options...
white90 Posted September 11, 2005 Author Share Posted September 11, 2005 that would only be 2ft long. out of the battery box up through the seat box and staight into the fuse box. it will be double insulated cable. does that sound ok Les/Ralph Quote Link to comment Share on other sites More sharing options...
western Posted September 12, 2005 Share Posted September 12, 2005 Sounds OK, but 2 ft of cable can get very hot if anything goes wrong, think I'd go with a fuse at the cable to battery connection, and not have to worry about it Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted September 12, 2005 Share Posted September 12, 2005 out of the battery box up through the seat box and staight into the fuse box I would fuse it as near to the supply as Les says, every time you go through a panel, even if it's properly grometted, there is always the chance it will get damaged. If that happens you won't need the heated seats Quote Link to comment Share on other sites More sharing options...
white90 Posted September 13, 2005 Author Share Posted September 13, 2005 job done testing Quote Link to comment Share on other sites More sharing options...
