freelander v6 2.5 2000 auto
molly
Hi Freelander v6 2.5 auto low miles in good condition now has gearbox problem fault code P0748 pressure control valve open circuit has anyone done this job is it a big job to remove gearbox any advice thanks
Shouldnt need gearbox removal , most problems are electrical valves , that are in behind front cover pan . It could be a wire , or the actual line pressure duty solenoid JF506E.SOL09 it sits vertically on the valve body on drivers side looking towards front of engine assy . HTSH
