Cooling advice
300 tdi defender. Auto.
1.6 transfer box.
Running on 35.10.5.16 fedima siroccos.
Rear mounted . Full length brand new defender td radiator.
Twin cooling fans .
Davies craig electronic water pump with controller to suit.
Water pump impeller and thermostat
removed.
Brand new cylinder head and gaskets .
50/50 antifreeze mix
This is the problem or not .
Outside temperature 26 degree's.
50 mph constant speed.
Temperature gauge sits between 100 degrees and 105 degrees. To me this seems to warm. But it's a constant reading backed up with the davies craig temperature reading.
When I drop down to 30mph through town it drops to about 90/95 degree's.
and on idle it sits at 85ish after its cooled down .
Is this OK ?
Or am I getting over paranoid ?
My only next thing I'm going to install a roof scoop to direct cold air behind the can
Sounds like a reverse vortex coming off the front of the vehicle and working against the fans. Do the fans have a proper fan-cowl in the form of a box? (As opposed to two fans lying against the rads fins)?
Landys have funny air flows. At 30mph a sheet rolled up in front of the vents started moving toward the bonnet edge!
Put the thermostat back in it's there for a reason without it there is no control over water temperature or flow. I ran a 200tdi tomcat with rear rad for 5 years as a daily driver several trips to Italy never a problem I had standard water pump, standard thermostat and an electric fan (that very rarely ran).
Mike
