elbekko Posted August 12, 2015 Share Posted August 12, 2015 On my P38/D2 steel wheels, the valve stem is very loose in the hole. On all except 1 I can push it through by hand. This causes them to leak, unless the tyre is at 2.5+ bar, not so ideal for off-road. They're currently the normal snap-in type. Would a bolt-in valve like this or these help? Or do I just need a different size, if that even exists? And if the bolt-in ones are the solution, does anyone know where to get some that aren't chrome? Quote Link to comment Share on other sites More sharing options...
HoSS Posted August 12, 2015 Share Posted August 12, 2015 I always thought the push in rubber type were better. The whole body seals into the hole, and takes some abuse. IMHO the bolt in type could suffer from a o-ring failure, or be damaged by knocks... Sounds like you just have the wrong size. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 12, 2015 Author Share Posted August 12, 2015 So there are actually different diameters? I've only ever seen one bin of the things, only difference being length. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 12, 2015 Share Posted August 12, 2015 Definitely two different diameter valve stems. I know the thicker of the two are fitted to the old 'Rostyle' range rover rims Can't comment on the P38 wheels though sorry Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 12, 2015 Share Posted August 12, 2015 You should need a valve tool to pull them through, not by hand Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 12, 2015 Author Share Posted August 12, 2015 Aha! Yeah, I know you should need the tool, that's what tipped me off initially that something was wrong. And then also the leaking. I'll go look for some bigger valve stems on the interwebs then. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 12, 2015 Author Share Posted August 12, 2015 Err, I found this page: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=208 Which states there are two diameters for passenger cars, 0.453" (11.5mm) and 0.625" (15.8mm). 4mm difference seems like a lot. The current ones very loosely pop in. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 12, 2015 Share Posted August 12, 2015 Take it to a tyre garage, sounds like you've got the small valves in big holes, they should put up quite a fight, mine do Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 12, 2015 Share Posted August 12, 2015 The smaller size in the bigger holes would be very obviously wrong I'd have thought. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 12, 2015 Author Share Posted August 12, 2015 The smaller size in the bigger holes would be very obviously wrong I'd have thought. That's my thinking as well. I just can't imagine any other reason why the hole would be oversize. Still, 4mm difference in diameter seems like a lot, even if they're supposed to put up a fight. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 12, 2015 Share Posted August 12, 2015 pop one to one side and measure the hole in the wheel. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 12, 2015 Author Share Posted August 12, 2015 I was hoping to avoid doing that more than once But yeah, it'll be the best option I guess. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 17, 2015 Author Share Posted August 17, 2015 Just tried to have a measure. Didn't find anything sturdy enough high up enough to jack the tyre off the wheel, so had to go for a risky measure, holding the valve stem while measuring Seems to be 15ish mm, so you guys must be right. I'll order up some of the bigger valve stems. Quote Link to comment Share on other sites More sharing options...
