diggervan Posted August 19, 2015 Share Posted August 19, 2015 Hi just had truck remapped (td5) seems to of worked lods more power only thing I don't like is it chucks black smoke out when engine labours once revs to gears match up smoke clears and it's fine So is this normal or should i get a les aggressive map Because were I got the map done there's a choice of 3 maps and you get 30 days to chose or put back to standard and your money back Any thoughts. Bob 1 Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted August 19, 2015 Share Posted August 19, 2015 got any details of the place you had it mapped? sounds like a quantum dealer (like us) my advice is boost need to be set via the actuator rod! something i hightly dounb they changed. hence the smoke as its over fueling. my advice it so pop back and check if they adjusted it. if they did ask them to send map back off to get checked. (mistakes do happen) HTH. Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 21, 2015 Author Share Posted August 21, 2015 got any details of the place you had it mapped? sounds like a quantum dealer (like us) my advice is boost need to be set via the actuator rod! something i hightly dounb they changed. hence the smoke as its over fueling. my advice it so pop back and check if they adjusted it. if they did ask them to send map back off to get checked. (mistakes do happen) HTH. I've been back intuch with them United deisel and they don't build maps themselves they get them via someone else and they did not alter boost just installed mapIt's in for mot next week if the emissions are a problem I'll have to go back and try the other two maps and see how that goes Thanks. Bob Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted August 22, 2015 Share Posted August 22, 2015 persoannly i would shorten the actuator rod by 2-3 turns then give it a blast down the road. if it still smoke, the shorten further by 1 turn. stil smokes then i would put back to standard and get the map looked at/adjusted. with a td5 remap, you cant just add more fuel without more air. Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 22, 2015 Author Share Posted August 22, 2015 persoannly i would shorten the actuator rod by 2-3 turns then give it a blast down the road. if it still smoke, the shorten further by 1 turn. stil smokes then i would put back to standard and get the map looked at/adjusted. with a td5 remap, you cant just add more fuel without more air. yes I agree about the fuel to air mix if I get chance I'll have ago with shortening the rod tomorrow thanks bob Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 23, 2015 Author Share Posted August 23, 2015 Hi had chance to have a look today after I gave up with the f------- door parts needed for that anyway went to adjust the rod on turbo as suggested and noticed a intake pipe the one under turbo was not spit but v soft and perished so just wondering if that could be the problem and the remap has just highlighted it so I'll replace that first if no better I'll adjust rod then. Any thoughts Bob Quote Link to comment Share on other sites More sharing options...
sandu_222 Posted July 3, 2016 Share Posted July 3, 2016 I have similar problem Defender, TD5, remapped, allisport intercooler, wastegate reconfigured as requested after remap. The car smokes when climbing (when the boost is big), I don't have tacho, but I guess somewhere lower than 1500rpm then it disappear and the car drives well if I stay in place in Neutral, and put full throttle, the car smokes a lot Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted July 3, 2016 Share Posted July 3, 2016 I have similar problem Defender, TD5, remapped, allisport intercooler, wastegate reconfigured as requested after remap. The car smokes when climbing (when the boost is big), I don't have tacho, but I guess somewhere lower than 1500rpm then it disappear and the car drives well if I stay in place in Neutral, and put full throttle, the car smokes a lot when you say reconfigured, i assume you mean adjusted to increase boost? need to be more carefull as defenders wont go int limp mode when over boost when compared to discos. when remaped did they surgest what psi to adjust boost levels to and have you got a boost gauge fitted? Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted July 5, 2016 Share Posted July 5, 2016 My Defender TD5 is mapped and does smoke when under load but clears when boost builds. I have a fast road map with boost increase to 20 psi as recommended by the tuner. A common problem for black smoking is the turbo elbow going soft with age and collapsing under high boost, so this might need changing. Toby Quote Link to comment Share on other sites More sharing options...
