Mo Murphy Posted August 23, 2015 Share Posted August 23, 2015 Can they be swapped ? For example swap a td5 serpentine pulley for a v8 type double v-belt pulley ? Mo Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 23, 2015 Share Posted August 23, 2015 Can't see why not... But I've never had the need to take one to bits.. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 23, 2015 Author Share Posted August 23, 2015 Well I had a bash at the td5 pulley. I removed the centre bolt and removed the cover. The pulley appeared to be held by a large circlip which I removed but the pulley won't budge off the shaft and I don't want to force it and break it. Anyone dismantled an air con pump ? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 23, 2015 Share Posted August 23, 2015 Are there any diagrams on tinterweb? Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 23, 2015 Share Posted August 23, 2015 Murphy, I'm not too sure about a Td5 (no experience) but on the 300Tdi it just pulls off along with the electric clutch, yours might be seized on, so use some WD40 and a heap of patience. For correct operation the clutch needs a .025" gap between the plates, this is adjusted by shim washers. Quote Link to comment Share on other sites More sharing options...
