boaterboy Posted August 23, 2015 Share Posted August 23, 2015 This isn't a joke question! When I turn off the engine there is a momentary, quite noticeable 'chirrup' sound from the engine compartment! No trapped bird(s) as far as I can see! Can anyone throw any light on what it might be, please? All jokes will remain the property of the originator! Quote Link to comment Share on other sites More sharing options...
bear Posted August 23, 2015 Share Posted August 23, 2015 Hi, Try searching info for crank pulley on Youtube. Also have a look here http://www.discovery2.co.uk/CrankPulley.html HTH, Griff Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted August 24, 2015 Share Posted August 24, 2015 It might be related to the serpentine belt moving on the pulleys as the engine stops. Its alleged by a few people that genuine LR belts are slightly different material & grip the pulleys better - and don't make this noise. Our td5 does it. I've checked the crankshaft pulley & it's fine, but haven't changed thr belt yet - as it appears to cause no other problems. Paul Quote Link to comment Share on other sites More sharing options...
wanger Posted August 24, 2015 Share Posted August 24, 2015 crank pulley Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted August 24, 2015 Share Posted August 24, 2015 Mine did that when I replaced the belt & tensioner..... (A lesser known brand of belt... Can't remember the brands but not blue box....) Got hold of another and the problem went away. No issues with the crank pulley when I tested it.... Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 25, 2015 Author Share Posted August 25, 2015 Thank you all for your help. Really appreciated. Some really excellent leads which I will try. Quote Link to comment Share on other sites More sharing options...
