88inchthing Posted August 29, 2015 Share Posted August 29, 2015 Hi all. Just wondered if anyone has fitted a 300 24 spline front axle to a Defender 110 200 tdi? My 200 axle is shot (sloppy diff, discs, Pads, Calipers, and swivels). Seems like a good idea to source a mint as possible 24 spline unit and fit the whole thing. So far as I can tell should bolt straight up except for maybe the prop. Also i believe the 110 Defender brakes are bigger? Really would be nice to hear from someone who has done this before. Thanks in advance Bill Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 29, 2015 Share Posted August 29, 2015 Go ahead and do it Bill, you may also need the 300's radius arms as well as these are wider (although very late 200's had these too) HTH Mo Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 30, 2015 Share Posted August 30, 2015 May need to change the flange on the prop yes depending on what comes with it. You'll need to swap your Defender calipers/discs over, or source new ones, or rebuild your current ones. Disco/RRC front brakes are different. Quote Link to comment Share on other sites More sharing options...
88inchthing Posted August 31, 2015 Author Share Posted August 31, 2015 Ok thanks for the info. Best I start looking for an axle me thinks. Quote Link to comment Share on other sites More sharing options...
