sixtwoeight Posted September 9, 2015 Share Posted September 9, 2015 Hi all, Ive had a search and it seems that the fill plug is not also a level plug which seems a stoopid idea - anyway without draining out all the oil and re filling with the correct amount, does anyone know where the oil level should be in relation to the fill plug. I only want to top it up as has all been serviced fairly recently. Thanks Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 9, 2015 Share Posted September 9, 2015 Up to the fill hole, I've never seen otherwise. It's still an LT230. Mo Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 9, 2015 Share Posted September 9, 2015 Transfer box is a fill/level plug. You can stick your finger in, or use a mirror and light to check it. Unless you're talking about the gearbox on a 2007 Puma, which is 2.2 litres and the fill plug is not a level plug. Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2015 Share Posted September 9, 2015 I suspect the Caution at top of this page from my Tdci manuals is incorrect as it does not give the transfer box oil level plug location, but the text at diagram calls it a fill plug,which we all know is the same fill/level plug, fluid level is still 2.3 litres same as any other 90/110 LT230 transfer box. Quote Link to comment Share on other sites More sharing options...
sixtwoeight Posted September 9, 2015 Author Share Posted September 9, 2015 I suspect the Caution at top of this page from my Tdci manuals is incorrect as it does not give the transfer box oil level plug location, but the text at diagram calls it a fill plug,which we all know is the same fill/level plug, fluid level is still 2.3 litres same as any other 90/110 LT230 transfer box. I think it is this caution that i and others have seen and therefore assumed the fill plug is not also the level.. Anyway from all your replies it appears i am wrong! I shall top it up as necessary - cheers Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 9, 2015 Share Posted September 9, 2015 I suspect the Caution at top of this page from my Tdci manuals is incorrect as it does not give the transfer box oil level plug location, but the text at diagram calls it a fill plug,which we all know is the same fill/level plug, fluid level is still 2.3 litres same as any other 90/110 LT230 transfer box. Interesting. Wonder why that is, as there's not much difference to earlier Tboxes. The 96 manual calls it a filler/level plug. Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2015 Share Posted September 9, 2015 as does my 1999 Td5 rave manuals info Quote Link to comment Share on other sites More sharing options...
